Right so my car is really hard to start, i've replaced the usuals but im yet to change fuel pump and MAP sensor, but the starting problem dissapears when i bleed the coolant. When i changed the head gasket and changed the coolant temp sensor it involved taking the water out and then putting it back in. Both times after this it started first time. Today i found alot of air in the system, when i took it out the car started first time and still is...
Is it possible that air in the system is causing the problem or is this just coincidence?
nick
nick
