Airbag/serv light, but not the usual
I've had an aftermarket steering wheel and seats for a while now, and when first bought, I'd done all the right things with resistors etc to keep these lights off.
It all went through a mot with no dramas
recently the lights came on and no amount of fiddling has turned them off. I've had diagnostics on and these are the faults
9007 - Drivers front airbag circuit
900C - Front passenger thorax side airbag circuit
9031 - Drivers front seat position sensor circuit *
900B - Front driver thorax side airbag circuit *
9008 - Drivers front airbag circuit 2 *
9013 - Passengers side front buckle pretensioner *
9048 - Fault warning light coherence circuit
* - didn't clear
Any ideas around this? Is it a case of finding someone with clip or disconnecting the battery and replacing all the resistors?
All help appreciated :)
len_beach
  E92 M3,172 track car
Is it an issue with the lock in the passenger door to disable the airbags?
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
More likely to be an issue with the resistors you've fitted to those trigger lines. Check your resistors.
Mick
I disconnected the battery, replaced all the resistors but still have the lights on, cant get to a diagnostics atm to find out which ones are the issue, but i assume it's still the same issue.
