Airbag/SERV lights - Any suggestions?
ChrisCurr
Car  RenaultSport clio 17
Can anyone help?
Both Airbag and SERV lights have just come on this afternoon, anyone know why this would happen?
could be a dirty or loose connection within the airbag circuit, a diognostic plug in would be quickest way to work it all out
under ur seat if it is a 3 door... ders like a little junction box push the wires in abite r fiddle with them that could fix it
had this happen to me - ended up taping the connectors togetehr to keep em from falling apart from one another
unplug the connector, spray some electrical contact cleaner on it, when its dry plug it back in firmly, should be fine then
I unplugged the connector under the passenger set and reconnected it and it worked no problem. Cheers for the advice.
the first renault fix for the under seat connectors given a dry jiont hence putting the light on was to cut off plug/ socket and join wires together with blue butt crimp on connectors ,the 2nd fix was to solder and shrink wrap
