Renault Clio Sport V6 255
				Hi guys, would really appreciate some help as MOT runs out in a couple of days. Had a mechanic do some diagnostics and he said it needed a replacement airbag ecu which he then fitted, Ran tests again and no faults found but lights still on. My car is a 5 door 2004 Clio Dynamique dci 100 and the airbag ecu donor car a 3 door 2005 dc 65i Extreme. I've since read that the airbag ecu needs to be configured to my car but my mechanic is saying that if both cars have the same airbags then there shouldnt be any configuring needed. I kind of see what he is saying as each car has same airbag ecu part number (apart from an 'A' on the end of one)  and similar placed airbags, so what would be the difference in configuration of the airbag ecu between the 2 different models that would cause the Airbag & SERV lights to stay on?  Thanks for any help!
