Airbags + Airbag ecu removed still got lights?
  Clio 172
I've removed all the airbags and the airbag ecu but still got bag light and serv light on dash, Is there any way to get rid of them?
I heard from burp that there are wires you can cut anyone know which ones?
  Vee 6
I've done the same, I found that there is a data line from the Airbag ECU that talks to the UCH,
The Airbag ECU is feed with battery voltage at key on and if there is no comms with it the light stay's on (Doing it's job i suppose)
I tried refitting the airbag Ecu and adding resistors, The only problem i had while doing this was fooling the ECU that the sill crash sensors where still in circuit. ( Don't think you can resistor these ).
So i'm back to square one.
I'd be very interested how Burp did it..... I'm ready for desoldering the airbag and service lights out of my dash.
