airbox
  fiesta zetec s mk5 / 182
should i cut my airbox up to stop heat soak from the engine as ie just fitted a 57i kit or should i have a custom 1 made to semi enclose it and if so what materials should i use?
If you want :)
Maybe worth a shot :)
But i'd maybe try disecting an old airbox or one from a scrappy so you still have your old one to put ack on if need be.
But in my eyes Induction Kits are a waste of time all they do is suck in hot air :(
A decent panel filter in a standard airbox with a good air feed is probably sufficient though.
Unless you want to spend heaps of cash on an enclosed filter set up.
But hey its personal choice.
  ff 182
if you get fedup with it then you have no airbox to drop back on, i did the same with mine and had to fork out for a new 1 6months later. see if you can get a cheap one of ebay then butcher that one....
