Aircon Prob! New resistor fitted...
Car  CB1N
So I am left without aircon and even with no ventilation even though I fitted new resistor...The vent motor is ok, because I had tested it by shorting wires 1 and 5 going into the resistor unit (two thick black wires, both on each end of the connector). That had resulted in full vent speed on ignition.
New resistor changed nothing, I have no ventilation...The head unit lights up and I can change settings etc looks to be working fine but no air . I turn the AC button off and still no air.... May be faulty cabling to the resistor (red yellow or green wire) or even faulty connector...
I guess that the ventilation has to be in working order for AC to be able to operate, so I think that there is no need to check the gas, pressure switch or AC pump clutch untill ventilation has been fixed.
