Alarm install
  Naples Red clio 16v
If i were to get a clifford alarm for example, when they install it can they bypass the current immobiliser in the ecu (a 95 valver)? or would i need both the clifford fob, and my existing renault fob to start my car?
J
  Naples Red clio 16v
spoke to clifford directly and they said they could bypass the immobiliser by mounting the chip from my ke in a transponder behind the dash so it is always emitting a signal. has anyone had this done? my problem is that both of my keys don't work so what happens if it is the chip gone in both keys? shell out for clifford alarm then have to still shell out for replacement keys for from renault.
  Carrera 4S. Clio 172. M5
There is another way, but I wont go into it on an open forum. Go to see your local Clifford installer.
  "Navy" N17 TWO
The quality of Clifford alrams is in the actual instalation
Make sure you get an approved Clifford installer to fit it!
I have a clifford on the 04 ddci - the Renault immobiliser is disabled with the clifford keyfob - I don't need to press the key any more.
