M.C..
Yeah, -2.5 is a fairly aggressive setup for the road to be fair. And as I said, I think Track Torque messed up. -2.2 degrees marginally less aggressive with little to no noticeable wear from travelling back and forth, and it still performed well on track. What's a typical street setup? -1 to -1.5 degrees?Currently on Gaz golds
Tbh I have not had loads of wear to the inside edge due to driving on the road
Do you know the spring rates? Have you done anything else to increase the roll resistance e.g arb, stiffened beam etc.Currently on Gaz golds
Also do you know the weight of the car?
