ive been looking at alloy pedals, i asked in halfords and they said i could'nt put them on my clio because the acclerator pedal was plastic, is there any way around this?
pop off clutch plastic cover to reveal metal plate, pop off brake plastic cover to reveal metal plate, and leave the accelorator plastic one on as its just an L shaped bar.
The accl pedal needs to be removed (unclipped) then you have to play around with the mounting screws, it does work! Be careful with the plastic and you may need a dremel to cut some off.
If u put it in the wrong place ur screwed tho! as it will be wonky forever!
