Alternator on fire
Austin-182
Car  182
Evening all,
The stop and battery light have been on my 182 for a while now. I put a new battery on a couple weeks ago hoping that would be the issue, which it wasnt. I dont use the 182 as a daily anymore so havnt drove it much sine the new battery went on.
It has been starting fine without any issues.
Today i moved the car off the drive to wash and while doing the wheels i noticed a strong smell of fire and then smoke coming from the engine bay area. Luckily i had the hose ready with me so managed to squirt the alternator to stop any flames going up. I also have always kept a spanner in the glove box incase of battery failure so managed to disconect the battery straight away.
The issue i now have is that i cant drive to a garage to have it fixed so im going to try and find someone who can come to me at home to fix it.
Will i need to put a new aux belt on? I had the major service done last year and have covered around 2k miles only since then.
Sounds like an internal short on the alternator. Luck you were there, could have lost the car to a fire.
Couldnt believe it. If i hadnt got the bucket and hose ready first before I moved the car it would have been up in flames!
Aren't the water pumps driven off the timing belt on 1*2s?
I can't remember offhand, but what I do remember is Dan@SJM shredding the aux belt at Combe, cutting it off, and I'm pretty sure he had to keep stopping to prevent the engine from overheating whilst getting it back. May be wrong.
Take the electrical connections off the alternator and cable tie them out the way. Charge your battery up fully. This will allow you to drive enough distance to a garage.
I would not advise cutting the aux belt! With the alternator disconnected it will just act as a pulley.
A decent garage should be able to change alternator fairly easily.
But then you're still spinning the alternators internals and generating the heat..
Shouldn't do as unless it is seized. No heat will be generated otherwise. It will be an intenal fault in the alternator that caused it to ignite.
I have had the same problem(although I got an electrical burning smell as opposed to a fire) and this has worked on both occasions. Got me 12 miles home a few weeks ago.
I can buy a new alternator from Renault. They are £180 so thats OK. I just need to find someone who can come and help me fit it. Its still sat on the drive...
There used to be a Renault guy on here, from a dealer. He gave good discounts on new Renault parts.
I remember paying in the region of £120 for an alternator for my Cup. I cant remember the name though, take a scout in the trader section.
Used to be adam from wolverhampton reno but it drove him to a brake down.
My alternator also set on fire, and I did this to get it to a garage, it was fine.
