Am i supposed to have an interior temperature display on my 1.2 dynamique?
  1 Series Coupe
As above...
i have the temperature 'nipple' on the passenger side wing mirror... Is there a way of turning it on if i have one?
Cheers Matt
  Chocolate Bar™
if you have one it should come on instantly.
when i removed my wing mirrors it goes blank immediately. as soon as i reconnect the mirror it comes straight back on again. so your problem may lie in a loose/faulty connection.
first step would be to remove the cover, and have a check of the connector block, as the wires can get trapped/break under the cover if they get clamped down
  www.renparts.co.uk
can you use the electric adjuster to move the passanger side mirror? if not then the connector has come undone? if so then as mark says one of the wires might have come out of it?
ta
josh
  1 Series Coupe
i can use leccy adjuster toadjust mirror.. have taken cover off, and everything seems to be ok... wil i have to go to renault to see what they can do?
it is a 03 platee by the way...
cheers
Matt
