CLIOpatra, L22EE W™
				OK,
This question has been going around my head for the past few days. I am thinking about setting up an Amp and Sub in my Clio, also planning to run the front coax's from the amp and run the rear coax's from the H/U.
So the question I have is, if I am running the front coax's from the Amp, do I simply run a speaker wire from the amp the the front (to the coax's). Do I disconnet the speaker wire from the H.U, Then simply connect the speaker wire from the amp to the coax's. Do I need to cut the speaker wire running from the H/U, or can I just cover the spades (to stop the touching any metal) and tuck the wire away in the door where it currently is?
Maybe a simple question, but I just wanna check
