Amp???
Planning on using SPL Dynamics SD-6.2 RMS 80Watt front comps, http://www.caraudiodirect.co.uk/dynamics-sd62-p-5523.html?cadid=q2qdiul0436p9v60g919lvv342
and SPL Dynamics TD-502 RMS 50Watt rear coaxials http://www.caraudiodirect.co.uk/dynamics-td502-p-5511.html?cadid=q2qdiul0436p9v60g919lvv342
My problem is wether or not to amp front and rear or just front? As getting a 4channel amp which will match the specs of all the speakers seems to be a bit of an issue, either fronts will be under powered, rears over powered and vice versa. So wondering wether it would just be better to just amp the fronts of a 2channel and power the rears of the headunit which will be putting 50watts per channel anyway?
I have just amped my front comps and connected the rears to the headunit and I am well happy with the sound.
FYI the Amp is pushing 2 x 120W to the fronts, which are something crazy like 210W PMPO and the rears are 85W.
