And again....Rstuner
Car  RS
I did some programming with RsTuner and now when I connect the "car" to the Rstuner the software screen comes up (the software you previously flashed) it's called gathering info bla bla....Now when I want to switch to a different cal file the lines are full...I mean I don't see the date anymore of the last file because there aren't enough lines to print it...Do you still know what I mean ?!?!?
Well question how can I empty these lines so I can see what cal. I'm running ??
Question two when you flash is the little red engine on your dash blinking ??
thanx all for the help
Clearing programming history is not possible. To see which version the ECU is running, look under 'current' on the ECU information tab.
dear fastchip I'm using version 1.67 beta for programming but under edu information I do not see a current session. Where is it about ?
