I am thinking about wiring up my door speakers to a four channel amp, and then use the RCA out on that amp to link it to the monoblock for the sub.
In terms of power leads is it OK to bridge them, ie. power the 4 channel as normal and then take the power lead from that to the sub amp too?
I also have a couple of questions with regards the actual installation of the amps.
Firstly, I have heard that it is best to run the power cables and the RCA cables down seperate sides of the car, is that right? And does that also apply to the speaker cables?
Then secondly, how do I actually go about connecting the remote power cable to the stereo/car wiring loom? Ideally I don't want to be chopping the wiring loom up, but I have considered a chocolate block connector, just wondered if there was a better way of doing it?
Cheers guys
Cheers guys
