Clio Vvt Gt
Hi all, I have recently purchased a mk3 face lift clio Gt (59 plate) and I can't get the cruise control to work.
I have sieved through many posts but can't find the answer I am looking for...
The problem...
All fuses checked out okay.
Cruise and speed limit switch operates fine.
Dash lights up with correct symbols and message displays set... On the dash.
Both the clutch and brake pedal switches operate correctly.
Squib replaced as matter of course (correct squib removed and fitted)
Had the car plugged in at Renault and they told me they couldn't see the inputs from the steering wheel buttons
All buttons on the steering wheel tested out okay with correct resistances through to the back of the squib.
Still can't get the darn thing to work??
Only other think I can think of is relays?
I am unsure where the wiring goes from the multi plug on the back of the squib? Does this go to a control relay or strait to the ecu?
Please help...
Thanks in advance
JOSH
The problem...
Please help...
Thanks in advance
JOSH
