little clips behind the steeringwheel, turn it to the side and look through the windscreen you will see them 2 or 3 from memory and full airbag comes off as one, worth disconnecting battery first and leaving it for 10 minutes before doing it.
Two clips behind the steering wheel, at 3 and 9 o clock. As said turn the wheel 90 degrees and you'll be able to see them.
Use a screw driver to pop the U shape hook off. One on each side then you can remove airbag, remove two connectors at top and bottom.
Are numerous guides in guide section but you have to be a full member.
