Another Ph1 problem.....
Barron
  Turbo S,Exige,R5,182
missfire this time lol! well i think its a missfire. Around 3k rpm in any gear you can hear a bang and the car misses, while this is happening the rpm needle is going mental.
Changed the coil pack so far and that hasnt sorted it. Will change the Leads tomorrow. Then will check plugs but they are new-ish.
Any other ideas?
ta
carl
Barron
nope cant tell, had a quick look last night and changed the coilpack but that aint it. Getting some new leads and some spark plugs to be on the safe side :)
/carl
Barron
could be the lack of proper mapping causing the problem ;) Seriously think you should get the RS Tuner
lol will be getting my 2nd RStuner sometime this month. Already got one for my road car but dunno about buying another license for it due to the fact that it will lock to the track car.
/carl
does it not then work with both cars?
Have you the PRO version? If so, and you can use the same kit on both cars with the new license, get the wideband sensor kit with the money you wuld have spent on the second RS Tuner ;)
Barron
just got the standard kit for my road car. For the track car i will be buying the pro kit and the wideband sensor kit.
Expensive :quiet:
ah ok! Might be worth a cheeky email to Henk about having two licenses on the one unit, so you can use the same one on both, and then you can sell on the standard one.
