Clio 1.2 Dynamique51
another problem has now developed with my mk2 clio. Whenever i start the car for the first time each day the engine will rev like mad between 1,000 and 2,000rpm, and then will cut out. It is then hard to start again after that and eventually will start by pumping the accelerator whilst turning the key. Once started, the runs badly with it cutting out everytime you pull away unless you rev it like crazy and then sometimes there is a lack of power. Once up to temperature it is fine. Does anyone know what is causing this? ( i have tried describing it the best i can)
thanks
thanks
