Another RStuner question
Car  VX220
had a search but no luck so have a quick question.
Right got my rstuner sorted and have saved the original ecu file.
My software version is 6400 and engine is CB1N so i know that i will install the 6400_2A07.rst file.
For the CAL file i have read that people have tried both the ron98 file and the groupn files. The only groupn file i can find is A300_35FF groupe_N .rst which doesnt seem suitable for my ecu. Does that mean i can just use the ron98 file.
Chris
nice one thanks. Also before i upload the 98ron does it matter that i have some normal unleaded in my tank as my dad filled it up for me the other day. Or shall i run it almost dry and then fill it up.
Chris
no mate it waont matter. This came up before, the map is made with this in mind so there is a "tollerence" meaning it can run on either but will run better on the 98ron
right i uploaded the .rst file and the rev limiter seem to go up to around 8k. Then this morning i uploaded the 98ron .cal file and the limiter seems to have gone back to standard. Is it best to just keep the original calibration with the .rst file or keep the 98rol cal file.
Chris
so why does it tell you to run the .cal file. If you hover your mouse over the .rst file then is says groupn so that must be the difference.
