Another Sky HD question
Car  Clio Williams
I live in a flat which has only got a single sky outlet on the wall. If I wanted Sky + or Sky HD could I take that signal and DA it out to the two inputs on the back of the unit so that it still works?
You can't simply split a feed into two (like a terrestrial signal) due to the positive/negative modulation done by the LNB.
Saying that you'll be fine with a single feed if you're not too fussed about recording one channel and watching another.
thought that wouldn't be the case. So Sky HD only uses one connection from the Dish.
You need two feeds to fully utilise the Sky + aspect of the box.
Not sure what you mean by "So Sky HD only uses one connection from the Dish." It implies you think HD material needs 2 feeds or something?!?
Does the Sky HD box work in the same way as the standard box and only needs the single cable into he back for HD pictures as well as the subscribtion charge?
If you only have one cable, you'll only have one feed. Sky HD works fine over the one. The additional one is for recording two programs, or watching one and recording one.
If you have one cable, you'll just be able to watch one, or record one.
cool thats ok then just didn't think it would be worth getting a box if it did not work over a single cable because i couldn't get the information out of sky themselves.
they change your dish for free, when i got my sky + they just came put a new dish on an hey presto it was fine.
