anti roll bar bushes
anybody know how much would it cost to replace the two anti roll bar bushes ,the ones that join the lower arm/wishbone,cheers.
franx, what are they then?they join the anti roll bar to wishbone/bottom arm,made of rubber with a bolt through them.just assumed they were a bush.
If it's what I'm thinking of it's just a bolt with a rubber bit that sits between the lower and upper arm, I went into the dealers and just asked for an ARB mounting bolt.
rich-6,yes they do cause knocking.you can see tthem without jacking car up,just stick your head under and you will see anti roll bar joining bottom arm just give it a tug and you will see it come away from arm.if that makes sense.
