anti roll bushes nackered
could a knockin from left hand front wheel on slow right corners be caused by worn out left roll bar bushes. ?
everything elses seems fine after jacking it up but the top bushe of roll bar has had it.
cheers mike
Just knocks once? Or a repeated knocking? If it knocks over and over again on tight corners it could be a dry CV joint from a knackered gaiter.
Well, maybe... Thats what mine was!
the gaiter as very slight split about 3mm long just nest to the outer clip but i dont think its lost much grease. could i squirt some grease through this and patch it up with a bit of bike repair patch??
