any advice for diy cambelt and aux belt change?
  182,mx-5 mk1,mev sonic 7
iam planning in doing one myself if i buy the kits for it.
do i need any timing tools or any other special tools to do this or is it straight froward?
suprised no one had done a guide fore this yet!
any problems i might encounter etc
:D
  Lionel Richie
you need 2 cam locking tools for the cambelt and the crank pin, and i've made my own tool for the aux belt
Fred whats the engine code for the 182?
and what tool do i need for the aux belt what does it do?
  Lionel Richie
its a 3/8th's bit on the end of a bar at 90 degrees basically, you need it to release the tension on the belt
engine code is F4R738
  Lionel Richie
front bumper and grille
slam panel and bonnet catch (female bit)
undo the aircon brackets
undo engine mount (i undo the dogbone too, but you don't have to)
jack up engine and remove aux belt with special tool
replace aux belt tensioner and idler (i do 95% of the time, others don't)
airbox out
plenum off
cam plugs out insert special tool
crank cover bolt out insert crank pin
ali and plastic belt covers off
crank bolt and pulley out
replace belt/tensioners/idlers
slacken off inlet and exhaust pullys and time up
put it back together
thats a brief version, 5-7hour job for a pro
maynard
  ph2 172 track car
airbox out
plenum off
not exactly a simple job then eh?!
