Quote: Originally posted by Dean on 26 November 2003
iv emailed ktec
they said none of their brakets will fit the brembo due to the spacing on the caliper
im wondering if i can some home adapt it using shims etc if u can tell me what they are!?!!?!
I wouldnt have thought you would have been able to adapt the K-tec (Billet) ones, the difference between the bolt holes on the caliper itself would be different.
Easiest way to describe shiming would be to say that; if you had a braket produced the caliper would need to sit dead central across the face of the disc (as it is fixed), to move the caliper out you would need to shim (space) the caliper, to move in you would need to machine the face of the bracket. Think that makes sense!
Dont give up on it though as it would look absolutely mint with a set of Brembos on it, heres one more lead for you (depends on how far you are away from the midlands). Give Aldon Automotive a call, tell them what kit you have and the fact you need brackets engineerig to fit it to the Mk1 Clio and see if they can help, there number is 01384 572553 and they are based in Brierley Hill.
