Anyone else had an issue with a jammed seat runner too?!
Car  ph1 172 Excl, Cossie
Morning all,
In short the most annoying fault of this car so far, the passenger seat would only go back a few clicks from the front, so I tried 'helping' back a little further an now its jammed!
Anyone else had this? Is the runner mechanism detachable from the seat if it is trucked? I will whip it out at the weekend...
Thanks a lot
Weeksy
I haven't had the problem but the seat runners aren't the best or most adjustable.
Runners come off from the seat very easily if you need to replace them. Just 4 bolts and the cable for the tilt forward mech.
Morning Graham,
Thats good to know, thanks a lot Mr.
Worst case I will be on the phone to Renbreakers again!
Much appreciated
Weeksy
My drivers seat runner jammed all the way forward soon after I got it, I did have the runner off to see if I could fix it but nothing seemed obviously amiss so just bought a previously enjoyed one of eBay in the end (might have been Renbreakers actually) and replaced it. It seems to be a case of 'they all do that, Sir'.
Morning,
Thanks for the reply Mr.
No way, all the way forward?! I hope you have little legs?!
I did think I would remove it and there be nothing apparent, so I have spoken to them about a replacement!
Never had this with any other car!!
Mine has issues too.
I fitted the 1*2 half leather seats a while ago, and they both worked fine in terms of slide & tilt etc.
But now if i tilt the drivers seat forward, it doesnt slide to let a passenger in the back.
So troublesome bloody things then!
And putting the fixing bolts under the car... Thanks Renault!
I cant wait to remove this at the weekend now!! No, really I cant!
Inner bolts are behind the exhaust heat shield and look fun!!
Are they troublesome then?!
Tbf its not too bad a job, as long as you can get right under the car.
On mine there was cutouts in the heatshield so they were easy enough to get to.
One of them (black & red one iirc) is a b**ch to get apart, im not actually sure if its meant to!
