Anyone had problems with car just cutting out?
Car  1.2 16v (Race Spec)
As above, every now and again it just cuts out?? Happened this moring when on a dual carriageway overtaking a car!! sh*t me up!
When it happens the car turns back on and won't rev over 3k and won't let you go over 40mph (obviously no good in overtaking lane on d/c) Also the immobiliser light with the 'glowplug' symbol comes on. Dunno whats wrong.
Its a 2003 1.2 16v by the way.
some kind of throttle issue, check for broken wires on the injection loom they can cut through on the surcurity bracket at the back of the inlet manifold.
Could be any number of things with that engine throtle body wiring and the throttle body cleaning sound the most likly cause.
wkd_clio_16v said:
Will the fact that the car has never been serviced contribute to that?? Its on 31k at the mo.
That won't help but I don't see it as a the man problem.
31k though best get it serviced ASAP even just oil, oil filter and air filter.
Yes I'm getting that sorted when I get paid, long long time overdue. How would I go about getting the other problem sorted - Renault cost a bomb
Best go se Renault realy but you can clean the throttle body yourself if you take car just take it off clean it all up and put it back on.
Not too good with all that, I can get one of the mechanics at work to have a look (citroen), they will be able to sort that out for me even though its a renault won't they?
i had an identicle problem with my rsi it turned out to be a very damp ecu but its fixed now................. kinda lol
What about the crank sensor.I had a dirty one on a golf and it kept cutting out at speed...
ian
dunno if any1 has said this already but hadf a similar problem with mine, does the electrical fault light come on?
mine was the MAP sensor
its a small plug on the back on the engine on top left hand side, may need replacing.
maybe not, the dignostics machine they have most likely will only do peugeots and citroens
