Anyone here program in C?
  Saxo VTS
Hi.
I'm doing an assingment for college but currently stuck on an IF staement within my program.
Basicaly instead of running the IF the staement the program seems to ignore it and go straight to the end of the program (Press any key to continue).
#include <stdio.h>
#include <stdlib.h>
int main(void)
char surname[30];
char initial[1];
char dob[8];
int choice;
printf("Please enter your surname: ");
scanf("%s", surname);
printf("Please enter your initial: ");
scanf("%s", initial);
printf("Please enter your date of birth in the DD/MM/YYYY format: ");
scanf("%d", dob);
system("cls");
printf("1 - Arithmetic \n");
printf("2 - Conversion \n");
printf("3 - Result \n");
printf("Please choose a number to continue: ");
scanf("%d",choice);
if(choice==1)
system ("cls");
printf("You chose 1");
else if(choice==2)
system ("cls");
printf("You chose 2");
return(0);
It's fine up until the first part of the IF staement bu then on key press the program quits.
I'm very new to C so appolgies if the program is a bit crappy :D
Any ideas? Cheers.
  Saxo VTS
That is all the code!
Like I say, was working finr untill I put the IF staement in.
This is C, not C++ I'm doing btw.
  FF182 Brembo Max, BMC CDA
it wont work as your not telling it what to do after the if statement runs, it has the answer but cant do anything with it.
  Saxo VTS
Well I'm asking it to print their corresponding choice to the screen...or so I thought.
if(choice==1)
system ("cls");
else if(choice==2)
system ("cls");
return(0);
Surely that is telling it 'IF they choose 1 then print to screen "You chose 1" etc'?
Gay programming :p
Yeah it should work ok, sorry missed the printf
Does it actually print to screen before it closes
After the IF statement you have
return(0);
Try it without the brackets.
D
dick
programming suck balls. have to do it in my course.
dont know why any1 wud want to be a computer programmer.
Have you tried PlanetSourceCode ?
I only do VB and some C# so i'm probably not gonna be alot of help.
The only thing i wondered is if you've got multiple choices i would have thought you'd want a C equivalent to the 'switch' function in C# (or 'Select Case' in VB)
sn00p
  A blue one.
your scanf is wrong, should be passing a pointer to "choice" not the value.
G_F
  BMW M3 & Williams 3
Ahh, Programming, brings back happy memories
