Anyone know Lengths of the driveshafts? ph1/ph2/172 cup offside
As title? i can see a clear difference in the passenger side shafts of around 20mm but whats the lengths off the offside? i need a ph1 shaft and i dont have one but i do have a ph2 shaft with bearing carrier thing and a ph2 shaft without the bearing thing (the shaft did NOT come out of a cup)
I would like to know this, if the shaft you can measure is 20mm difference, what accounts for that difference?.
The cups subframe is drilled 10mm wider than a standard 172 ph2 subframe for the wishbones, so i assume a standard ph2 172 runs a 10mm wider track than a phase 1 172 but i really want to know the lengths to see if i can get a shaft from something else (scenic/non sport phase 1 e.t.c)
