cheers, i've fitted gaz coilovers today (182 ones with a little help from my diegrinder )
gonna nip down to lazalign next weekend to set everything up (i know the boss man down there) so we are gonna spend some time on it and see what we can do
now the coilovers are fitted its obviously running some positive camber.
any data would be gratefully received
WHen setting up make sure you have your tie rods and the rod ends EXACTLY the same length from the inner joints, this will prevent you having different bump steer settings on offside/nearside.
You can raise/lower the front/rear relative to eachother to affect from castor. The more castor the better, since you dont have an adj mount.
ooh, one more question, camber bolts. where's best to get 'em
....i've already hacked one bolt hole on each, don't wanna do the other, so i think my best bet is a pair of camber bolts
