Anyone seen this before?
Did a search on that page for Ford-Petrol, adn saw this in there:
Puma 1.4/1.7 +1 bhp £293.75
Worth it?
Clios:
Clio 182 inc Cup + 8 bhp £293.75
Clio Sport 172inc Cup + 10 bhp £293.75
Clio V6 Sport 255bhp + 10 bhp £293.75
Clio/Megane/Scenic 1.4 16v <03 + 6 bhp £293.75
Clio/Megane/Scenic 1.6 16V <03 + 8 bhp £293.75
Clio/Megane/Scenic 2.0 16V <03 + 10 bhp £293.75
Clio 1.2l 8V + 5 bhp £293.75
Clio V6 Sport + 10 bhp £293.75
Clio 1.4 + 5 bhp £293.75
Clio 1.8/Rsi. + 9 bhp £293.75
Clio Williams 16v/1.7 RSi + 10 bhp £293.75
Clio/19 16v + 10 bhp £293.75
Taken from an email from GDI
We will soon be able to offer ECU mapping on the 172/182
We are in the process of purchasing the equipment to be able to flash the std ECU
This will enable:
Fueling and Ignition changes
Rev Limit changes
Idle setting adjustment
Closed and Open loop modification
not only will we be able to offer a map that we develop for you specifically, but also some that will suit the std car and make improvments (rather like the R-Sport type setup)
This is due to demand, IMO though a chip on a std engine is not going to gain worthwhile increase in PEAK power, however I have been asked for it 100's of times and I am going to spend some time to get some improvments
We have fitted on several occasions SMT's to std engines by request and the owners have been really pleased, much to my suprise....
improvments in throttle and drivability have been reported
one of the main reasons for this is the open loop map on the std ecu is set to run leaner in the mid range areas to get the economy etc that Renault want, when we change the values we increase the fueling in those areas to give you more power lower down.
The overall "PEAK" net effect does not change much but the gains in the midrange areas are pretty good.
of course then when you change the intake and exhust etc etc the mapping can make best use of these changes.
