I'd not use Dell servers personally - whilst their laptops/desktops are vastly improved apparently their servers are still a way behind.
FLOL, really, and on what basis is that?It's not the spec, it's the build issues/quality.
If you have a look at the IBM blades, they're better than the HP c-series...
one question, have you heard of nonstop servers?The HP blades overheat their memory, and the c-class enclosure has a significant design flaw.
That renders them useless as a solution for HA environments...
LOL, OK, so there 'was' an issue (and i knew fully about this issue but i knew of no-one who was directly affected by it as HP replaced any power supplies in the batch within a day or 2 so very proactive) but this is not an issue now, and was such a small chance of anything happening before it wasn't worth worrying about but they dealt with it anyway.c-class enclosure has a single DC rail which has been proven to shut the enclosure down if there is a specific type of failure on a PSU. HP's response was to issue new, 'more robust' power supplies.
Cisco servers will indeed be an interesting one to watch...
but in the world of blades, HP are well ahead of the rest.I think you take yourself too seriously.
I do know what Nonstop servers are, and I'm well aware of what they are. I'm actually technical myself, so chill the f**k out and accept that there are two sides to everything. And that HP aren't the be-all and end all of everything. There's some proper awesome s**t out there, and HP are just a halfway house...
oh and just to make it clear Mike, when I said you were an IT Manager that wasn't meant in a derogatory way, i know there are two kinds of It manager, some know it and some know feck all about it and only how to manage.
I know you are a technical person, that goes without question.
I guess i have an advantage in that we are a partner to all the vendors so I get all the insider info form all of them slagging each other off to i can form my opinion from all the fud and not just the bits that get put on the internet. I also have all 3 chassis's infront of me to pull apart and test so that also helps.
Both Dell and Apple charge nuts money for ram. Best be solid gold ram for their prices!
HP BladesystemI'm moving that way myself now - all I get is second hand information from someone I'm buddies with at a reseller for everything, and the case studies and work they've done. Apparently the HP thing is something they got quite heavily thrashed for. They've also said the IBM blades have their own weaknesses but on the whole can sustain 'more' failures because of the different thought process gone into the backplane - although it was highlighted that they run less power supplies, theory being one goes pop and you replace it anyway. IMHO if you let a blade enclosure have 2, 3 or 4 failed power supplies you deserve it going down!!!
Aaaaaaaaanyway - just take a step back dude. I'm not as bad as this impression you have of me - I've put a load of work into the solutions I recommend (including 3 HP bladecenters, so I know their worth) and I think it unfair to dismiss that. I'm the only bugger in the team at the moment who will turn round and say 'no, if they want our business they'll send us an example to compare. If they don't, they know the competition is better'. Everyone else is a google-buyer.
