Apex -60mm kit spacing
Car  Clio Mk2 DCI 68
Hi, i'm looking to get this kit for my clio 55 1.2 with 58mm spacing. The kit is described as "Apex Renault Clio all exc. D/1.6 16V/2.0 Sport/V6 Lowers by 60 mm 98-(SP150-4060)". I have called the guy at venom motorsport but we were not 100% if the kit is for 58mm centres. I presume so because it says "exc. D/1.6 16V/2.0 Sport/V6" which are not 58mm. Any ideas? Thanks in advance
I assume were on about the phase 2 cars?
If so then 1.6 and diesel both use the 58mm hubs same as the 1.4/1.2 16V and 90% of the 1.2 8V. The 172 uses 54mm hubs but the kit not designed for the extra weight track of the 172 so won't fit.
If were on about phase 1 cars it gets more complicated as the 1.4 and 1.2 use 52/54/and 58mm hubs when Renault felt like it the 1.6 16V should all be 58mm along with the diesel though.
thanx edde, is a 55 plate 1.2 16v extreme 4. tbh I don't think I can go wrong with these. I will order and let you know for future reference.
Fitted them today no problems-nice bit of kit. At last the car feels alive on the road (for a 1.2 anyhow). The ride is hard but not to hard, very little body roll and was 58mm for strut spacing (55 extreme 1.2) just incase you were wondering.
