Clio 1.4 16v Dymanique
Right I have just bought this.. wired it all up correctly...
(a mate who works down at Halfords helped me out)
RCA to headunit
Remote to Headunit
Power to battery
Ground to Chassis
Speaker cable to sub
Also, what does the RCA do?
Anyway, everything has worked fine over the weekend, but today, i was driving home and the Sub just cut out...
now the sub wont power and the little power light on the amp comes on then goes straight off... or flickers abit... But been playing around and managed somehow to get the sub to work for like 3 seconds then it cut out again..
All the connections on the amp are pretty solid... we tested the cables to make sure there was a circuit and everything was good.. connected it upto the amp again and nothing... first off the light would flicker but the sub would still not work... now the light comes on when you turn the ignition on and then goes straight off...
Really confused... being trying to fix it alll day.. dont know what to do...
Anyone got any ideas of what has happened?
I find it hard to believe that the amp is faulty because it worked for about 3days fine... i didn't even have the sub turned up much when he cut out totally....
RCA to headunit
Remote to Headunit
Power to battery
Ground to Chassis
