KitsonRis
Went to lock the Clio this afternoon after working on it and it wouldn’t lock. The light on the fob was going when pressed. Looked inside and the immobiliser light was going mad and so was the oil pressure light. Opened the door and you can hear a relay in time with the oil pressure light
Put the key in the ignition and turned on (didn’t start the car) and all was fine. Took the key out and the oil pressure light was very dim and the immobiliser light was off. Locked and unlocked the doors and waited. And then it started again. Can’t seem to find what could be causing this. It was fine when I last was working on the car and put it away.
All I was doing this afternoon was removed the front arch liners and cleaned and kurusted behind there. Did get a little hand sprayer to rinse off the mud and cleaner.
My two thoughts are either the battery is low - it was a new battery back in October/November but I charged it the other week after not being used for several months and I’ve had the car “running” but never more than 5 mins and I had to start it many times. But it never got lazy at starting.
Or the car is currently in front axle stands so the front is tilted up so is it thinking low oil pressure? But this wouldn’t cause an immobiliser issue and not lock?
In the mean time I’ve disconnected the battery and it’s stopped
but any other suggestions?
Edit: I have just thought, there is an earth strap behind the passenger side arch liner which if I remember is a little green/blue. I wonder if that is causing it as I did spray water under the arches. But why would it cause this when the ignition is off only? I didn't want to try and start it while on axle stands to see if it still worked, might drop it tomorrow and check.
