Arghhhhh some 1 help me
  Titanium 182
before i go insane!
fitted a new gear nob had to be quite brutal to remove oe 1
now the i get his quite buzzing noise
if i rest my left leg against the stick it stops or hold it
then i moves about 1mm and makes it again
removed gaitor and cant see any damage
whats wrong its doing my head in
i have just chganged mine over to a new one and i havent had any problems?! after the sawing the other one off lol!!
could only really think that it would be slightly too big so as to make it vibrate inside? it would seem tight on the outside then but it could still be loose inside if you get me?!
vix :)
  Titanium 182
yeh i know what you mean vix iv checked that!
im going to clean my car then take the tw*t to bits!
bloody valvers no end of bother!
KDF
  Audi TT Stronic
try wrapping a bit insulating tape around the pole then re-attach the gearnob, that should stop metal on metal or metal on wood vibration.
  Titanium 182
IL TRY THAT then
thing is my gear nob works like this
metal clio stick
plastic cap
3 allen bolts that screw into plastic bit holding a threaded piece in
gearnob screws on to thread
  Titanium 182
iv now
removed nob and greased
and refitted tight
got under car removed heat shield that i thought it might have been catching
nd its still doing it
i think some thing internaly might be f**ked
so does any 1 know how 2 remove the stick and parts attached to it? eg the bit at the bottom so i can replace this
