Hi all,
Managed to get some time yesterday morning to review Auto Finesse's Verso All Purpose Cleaner (APC).
I've used a hell of a lot of these in my time, as you can imagine, so was interested to see what this product could bring to the table. APC is always in my work bag, as I use it in so many areas; tyres, arches, engine bay, shuts, generally around badges/nooks etc when going through a detail, so it's an important product!
Having recently received some second hand Brembos, the OCD kicked in again and I had to clean them up. These things have clearly been used hard and were very dirty/caked in brake dust, but a lot better than most I've seen going on eGay.
Look OK, right?
But looking a little deeper and...!
So got to work. I received some Verso through the post in the form of the Waxybox samples, so thought these spray testers would be the perfect items to use to test. I also received a full sized bottle through from the guys, almost a day after getting a PM from Sian @AF, so thanks again for these opportunities guys!
Reading the Verso instructions, it says (as per most APC products) to dilute as necessary. As this was pretty tough stuff I opted for 1:5 (left) and 1:2 (right) ratios;
Sprayed on and left to dwell before being agitated with a multitude of soft brushes;
Results - I found the caliper with 1:5 needed a second and third hit, to remove a decent amount of the surface grime, whereas the 1:2 worked much better first time around. Not rocket science, but there we go. The results aren't perfect on both calipers as they'll more than likely require an Iron Out style product to fully remove the marks on the underside.
Finally dried off and (having had a few Saturday night jars!!) polished with AF Tripple. I LOVE THIS PRODUCT. Regardless of the application, it works so well.
Finished for now;
Tomorrow and Tuesday I have a couple of days "working from home" due to an office floor reorganisation - having just had two tyres fitted, there is a load of tyre soap over the side walls. Very messy. As said, tyre walls are an area for an APC looking forward to testing AF Verso out again. I'll update the thread tomorrow, weather permitting.
Thanks again to AF and the speed of delivery of the 1l of product. Great service. Cheers guys.
Comments always welcome!
Look OK, right?
Finished for now;
