AutoCAD Revit help
Just a quick question, i've done a model in Revit for a project - i have created a walkthrough however when i render it - the building sort of gradually appears as the camera moves closer? Like you can see some of it, then a bit more appears!
What would be causing this? I want the whole model to be in view as the camera swoops around!
I thought it would be a render distance/focal distance setting. It rendered the video, 2 min 30 in about 15 mins and it's 1.7GB, so the actual rendering side of it it's chomping through.
i5 3570k @ 5Ghz
8GB DDR 1600Mhz
OCZ solid state
nv 9800GTS (it is a bit poor and a bottle neck)
