Aux belt still unchanged at 57,000 miles - is this common?
F
fletchie
Hi,
My 182 will shortly be due for it's 60,000 mile service. Whilst going through the service book this morning I started to remember a conversation with my then local renault garage about the aux belt and whether it needed changing at the 36,000 service. I telephoned Renault who confirmed it hadn't been changed as it was noted it was in good condition at both the 36k and 48k services.
Is this common - I'm alittle worried that it hasn't been done but have been told it is the Cam belt that would cause problems if that went and not the aux belt. I was also told that Aux belts don't often break down, if this is the case why do they recommend changing them at 36k?
I'm alittle confused as to what I should do at my next service. :eek: I don't want to spend out cash if it's not needed (i need new brakes and tyres anyway so could do without having the aux belt changed!) Any thoughts?
Cheers,
Jean
ForceIndia
  Gentlemans spec 200
I think it was changed to an inspectioin rather than a def change. Stupid IMO. You're coming up to cambelt time, so I'd bite the bullet and get them both done, Birchdown are only an hour from you.
www.birchdown.com
  182trophy & Williams
if its not been done the last 2 times, i would definately get it done on your 60k service, wouldn't trust what reno have to say tbh.
