Azureus Prob
  Punto/Clio GTT
getting dcd from it a lot and getting this error
my router is taking a long time to release port mappings, consider disabling this via the UPnP configuration
how i do that?
Tom
  EV (s)
Might have the same issue with that tbh.
What router is it?
DMS
  A thirsty 172
UPnP = Universal Plug and Play. It's basically a way for applications to dynamically configure port forwarding on routers so that non-techy people don't have to fiddle with NAT rules etc...
Azureus is configured to use UPnP if you're getting that error.
If you've manually configured port forwarding on your router, having UPnP enabled could be what's causing you to get disconnected (it may be over-riding the static port mappings that the router is listening on or something). If this is the case, disable UPnP.
On the other hand, if you haven't configured static port mappings, consider doing it. That way UPnP won't be an issue, and you might learn something in the process :p
riz
  Jaguar XFR
Bit tornado or shareaza,
Azureus really slowed my pc down
  Punto/Clio GTT
how do i go about configuring port mappings?
i aint messed with anything manually
DMS
  A thirsty 172
BitTorrent has its uses actually.
I pay for the Giganews platinum service, which is awesome. Anything relatively new I can max my 20 megabit internet connection out with, but sometimes if I want something old I simply can't find it on the usenet network. That's where BitTorrent comes in. I often find it better for "old" stuff, such as films released in the 1980's that haven't been re-released on Blu-Ray yet, etc... etc...
dk
  911 GTS Cab
i haven't used them for nearly 2 years now, theres nothing i haven't been able to find between newgroups and rapidshare.
Also, torrents are the highest chance of being caught, thats the important thing!
