B14 Spring rate
MrBlonde
Does anyone know what the spring rate is on the B14 coilovers please?.
As looking to keep the front but put a pair of full coilovers on the rear,so want a good match with the fronts.Will just be for fast road use.
MrBlonde
So would it be ideal to have the same spring rate on a full coilover on the rear?.as its obvs a different type of spring compared to the full coilover set up.
plenty
Is 285 lbs the actual spring rate, or the rate at the hub? I suspect the latter.
clio_ross
  Clio 172
I’ll caveat this with I’m no suspension expert, but when going from inboard spring to full coilover at the rear on a Clio, there is a change in motion ratio from 1.7:1 to 1:1.
IIRC, what this basically means is that a lesser spring rate is required for a full coilover to generate the same spring force at the wheel.
Have a search for ‘motion ratio’ on here, I believe Northloop Cup and others have explained it in the past much more eloquently than I can.
plenty
I tried a 450 lbs rear spring on a full coilover which was utterly undrivable on the road.
I went back to OEM fitment rear springs and separate dampers paired with front coilovers. I didn't see any advantage to a rear full coilover and was concerned that the rear turrets weren't up to the stresses that a coilover would bring.
MrBlonde
Been looking at the BC series compared to my B14s,thinking to keep the B14 and have the fronts rebuilt and maybe fit a PMS rear arb is another option.
Mr Underhill
What are you trying to achieve?
