Back springs upside down
Car  R26
I got my gaz coilovers fitted by a perfomance garage and the back springs are different, one is upside down is this correct as I have asked them and they said it's fine?
jus as a litle add-on from this.
today iv been fitting my rear coillys an got a bit confused on the rear springs/adjusters an which way round,i have them with th adjuster at th top as they sit ok but its cos the hexkey adjuster bit sits into the top hole with all th spring bellow an the small lip 4 th bumpstop holding th bottom off th spring
should i have th adjuster at the bottom so i can get to th hex an adjust?
jus wondering as spent a few hours an got th rears done(an hour jus for the bottom shock bolts a 1/4 turn a time!)
also do i need a springclamp 4 doin th fronts¿
coilovers are rokkor ebay non-sport
many thanks and any tips would b gd cheers
