badges help???
  • Thread starter Thread starter leeboy182
  • Start date Start date
L
leeboy182
I wanna spray my Renault sport an Renault diamonds but wats the best way to get them off an back on ???
pry them off slowly, and put them back on the way you took them off, DONT Brake any clips tho
ive heard th clio sign has 2 clips which speaks for itself but the renault sport sign has sticky stuff on back does it go back on easy ? an what about renault diamonds on the boot an bonnet?
Wash the area around the emblem well with warm soapy water; this will prevent scratches later on.
Apply heat with a hair dryer until the emblem is fairly warm to the touch, this loosens up the glue.
Use a plastic spatula or flossing wire to slowly begin breaking loose the glue bonding your emblem to the car.
Remove the emblem from the car entirely. Moving slow will usually help the glue pull away as well leaving less work later on.
Remove any left over glue with a goo removal product and a little elbow grease, but will be worth keeping the heat on . and again wash the area...
i had some spare double sided mirror pads which i cut to fit on the back of the lettering
