I believe you can buy additional leads or connectors for this but i'm in the same situation. The unit I have does not work with the controls on the wheel. Not sure what sort of job it is to remedy the situation.
Fitting is easy, pop your current stereo out, little yellow connector from the display plugs into the harness you buy and then it just sits in line with the stereo and other ISO connectors (think you only actually plug one ISO block out o fthe 2 into it though, can't remember).
