Battery light flashing!!
Car  N Reg modded Clio RT
on a short journey yesterday the battery light was flashing randomly. GOt in the car this morning and is doing the same, then got to traffic lights and all my warning lights came on!! then they went off and battery light still flashing.
What could it be? dodgy Earth somewhere?
first point of call for me would be to check connections on the battery are tight if that failed i would then check the earth to the chasis, and alternator earth matey, best bet is to just follow the cables around.
ok, just found out we forgot to screw on the red bit onto the battery terminal last time we undid it. Now it's lost lol
Screwed a nut on it with some vaseline instead.
Hopefully should sort the problem
not 100% at the min mate, just had a look in my haynes manual and cant find any info and cant really look at my car as im just about to head down to london, if no one elese has helped you by tommorow i will have a look under my bonnet. "edde" might be the best person to ask hes pretty much a technical guru on the clio, drop him a pm n im sure hell help
This is a problem for you. If you want the Red screw back onto your clio battery, go to a scrappy you'll get one there for a few pence or 5 finger discount.
to be honest i think the nut we've put on there now will suffice. ill keep my eyes peeled for clios in a scrappy though
