Bearing & Suspension Arm Part Number Please?
Can someone tell me the follow part number for 172 MK2??
1) Rear Wheel Bearing
2) Front Suspension Arm (w/ ball joint)
Thank You So Much!!!
Rear wheel bearing isn't that much best get a nw disks as well IMo infact replace both sides at once. The bearings a common part though used in loads of cars other motorfacotries sell them cheap £30 I paid list price last tiem i bought some.
As for the arm £100 list price ask for discount though there only about £45 to dealers I think. There an ordered in part though sounlikly to have them in stock.
Thanks Edde!
Where you recommend to get the bearing? Does Halford has it? I will change both. But not sure if I will get the whole disk cos it will cost a lot to send.
For the arm, does other Clio use the same one? Or 172 has an different one?
Can I get the ball joint seperately? Or I have to buy as a unit with the arm?
Thx!!!
  172 cup'd extreme
Genuine wheel bearing + disk + ABS ring are £70 Bearing on its own is close to £30 - i posted the part number a few months ago.
Suspension arm is £60 including a ball joint 172 and 182 arms have differnet part numbers- im told they are different but i can visualise any difference.
Ball joints are availible seperate non genuine are around £12 genuine around £30
Thanks Jon,
Sorry to ask again. But do I need to change the centre cap locking key?
May I ask U for help?
  172 cup'd extreme
When changing the bearing you change the centre nut this is provided with the bearing kit.
Email me if you need some help buddy
