Was a bit of a bugger tapping into the cigarette lighter wire cause it was so short, but after that not too much trouble hiding the wire around the edge of the dash. Also you will need some cable, as the one you get with it isnt long enough, so you cut it somewhere in the middle and extend it. I can help you with it this weekend if youre at Ks?
The 550 has arrived, when I get home I will look at the length of wires etc and see what you mean. I may just run it down the front for now and wait for some spare time before I wire it properly.
Does it come with a window thing like yours or do i need to buy that extra?
They are a piece of pi$$ to install! I have mine on the windscreen pointing through the non reflective part. You should be fine to put it anywhere in a 16v. I run the cable down the side of the console in mine.
