Belt and dephaser change- what other mods at the same time?
chris blue
Car  clio rs 220 trophy
My belts are due next year, so probably go the whole hog on my year 2000 phase 1 (88kmiles) and get the dephaser n water pump done too
So what performance mods can you do, which will save a tidy sum , when done at the same time?
I am more of a tinkerer than an all out, head on dismantle and reassemble engines, so these would be done at a mechanics with Clio experience
I am planning to get my cambelt / dephaser replaced early next year and at the same time looking to get cams fitted with a tailored remap on top.
I expect I will use Engine Dynamics in Essex for the work.
so what additional costs we looking at for 197 Cams then?
Can understand what Budgie says tho- only bought the car for little money.
any idea what 197 cams would do for a standard 172 phase 1 engine?
How much labour involved and are they tricky to fit when sorting the belts at same time?
Speak to bloke about it, but I think most people would fit cams at the same time as the belts for very little extra.
197 cams seem to be getting high 180s with very little mods.
Could be blokes super duper secret timing which helps out though ;)
If you're running a Ph.1 engine that matched inlets or at least an RS Stamped lower inlet will give you some gains over the more restrictive non-RS stamped lower inlet.
