Best Brakes for 182
  BMW E30 325iiiiii
Wat brake pads wood u guys recommend for road use on a 182, i cooked mine on the back roads dont think standard ones have much to give.
Craig
  4 wheels
ive got ebc greenstuff with brembo hc disks and they are fine. but alot of people recommend ferrodo ds2500
  Arctic Blue 182
I've just had my 36k service at a Reno Specialists in Sheffield, and they said I've only 20% left, and I need discs and pads, as the discs are corroded.
Would the recommendations in this thread all fit standard wheel and suspension setup, which I have on my 182, because the bloke where I had my service said that I have to be careful about uprating my brakes as some (discs/pads) will only fit with bigger wheels?
I'm really not clued up on brakes, but would like the best setup for discs and pads (fluid if necessary) for a standard 182.
thanks.
yeh these are standard size discs so you'l have no probs under the standard wheels. only an issue if your putting bigger discs / calipers on which is not really needed.
Brembo HC discs, Ferodo DS2500 and Goodridge braided lines.
+1, heat them up and they are a brilliant break package imo.
No fade etc either and i am running dot 5.1 fluid too. Cant wait for my first RS trackday this year.
  Arctic Blue 182
Where abouts is this? Need my cambelt doing this spring and trying to find someone local. Any contact details would be brill also.
Rob
Here you go mate. Says Rotherham, but it's just off Tinsley.
J S Services-Renault Specialist
Meadow Bank Road Darley Park Service Station, Rotherham, S61 2NF.
(01709) 550553
1st time I've used them, as I'm stick to death of Gordon Lamb. They did a good job.
He's got a mint Megane 230 parked outside, does trackdays and stuff, knows what he's talking about, so I felt quite confident, a Renaultsport owner servicing my Renaultsport.
